- Thu Feb 05, 2015 7:23 am
#4640
I have a 2004 sixty-5 and am having some electrical gremlins. Occasionally, when I have the bike at idle with both the indicators and brake lights on, the lights will momentarily die and the engine will stop. Also, the lights will occasionally not turn on when the key is put in until after the engine turns over several times from the kick starter. I've replaced the battery and have it hooked up to a trickle charger which seems to have helped a bit but the problem persists. Also worth noting that I have the boyer power box, am making about 12.7v at the battery while revving the engine, and am making about 15v ac of the stator.
