- Mon Feb 02, 2015 10:19 pm
#4636
This is on an Indian Bullet, motor running in neutral and every 5 seconds or so there is an audible clunk which I am convinced is from the gearbox area when I heard it.Apparently it is worse when riding. Owner has now stripped the box and nothing appears to be a problem.Gearbox has had sealed bearings fitted,I'm going to go and put it back together tonight, but I wondered if anybody had any thoughts on this. Also I got him to pull the timing cover to check the cams,tappets pumps and spindle but apparently they seem fine. This motor also has a Hitchcocks longstroke crank fitted that has done probably 25000ks
