- Sat Jan 24, 2015 1:36 pm
#4610
Afternoon all, Bertie's rear suspension top mount bolt is bent, further more the nut is seized on solid, the only solution is to cut it off, what I'm not sure about is the replacement bolt, can I use a normal one of the same size or do I need a special one, made of hardened steel or something similar.? Thanks
