- Sun Jan 18, 2015 4:24 pm
#4599
All is not as it should be with my '89 350. I have fitted a 4ah gel battery not long ago. It is mounted on its side under the seat, but that should be OK. in fact, it doesn't hold a charge more than a couple of days. That should not matter too much but even though I have a Boyer power box fitted, it won't start with a flat battery. I have to connect another battery if it's flat; then it starts easily enough but won't run by itself for a minute or so if i disconnect the jump start; OK after that as the gel has taken a bit of a charge. Any thoughts, gentlemen?
