By mauri
#4303
if someone has this laying around let me know
By simon
#41729
Our hosts have then for sale I believe.
#41730
Couldn't believe it, I had a bloke ring me this morning looking for one, I asked him if he had posted on the Hitchcocks board but it wasn't him
By mauri
#46350
under the principle of there’s more than one way to solve a problem.
3
2
1
done
Automatic Timing Device - the picture is of an auto advance and retard unit built into a magneto drive pinion. These were fitted on Lucas SR1 Magneto-equipped 350 and 500cc UK Bullets between 1956 and 1959(?), and meant that you no longer had to control the timing manually via a lever on the handlebars. When (cheaper) coil ignition replaced the magneto, the ATD was incorporated into the contact breaker assembly.
http://royalenfieldzone.com/products/vi ... e/2726.jpg
By simon
#46355
Elegant solution Mauri. I thought about trying to modify a chain sprocket version but decided in the end that they were only slightly less rare and that the quickest way to the highway was our hosts.
By mauri
#46359
the original pinion was damaged any way, so it was a trow away part so to speak.
i made it so it can be reversed engineers.
are host don’t have this part at the moment, and won’t have any for the end of the year!(maybe)
That, at first glance, does appear to be the very thing. It's an Indian supplier, and I'm pretty certain a number of SR1 mag equipped Bullet engines must have found their way out there if they now have used mags for sale with the ATD still on them. The web site in your link appears to be for trade enquiries, so perhaps they would want you to buy a minimum batch of 500!. A
