- Thu Jul 31, 2014 10:09 pm
#3971
My bullet has started to spit back through the carb again, mainly when started from cold. Having stripped and cleaned the carb several times, to no avail, I turned my attention to the sparks dept. I found the auto advance not fully returning, so removed the points back-plate to take a closer look. With the back-plate out of the way I found the mechanism working as it should. With everything back together I found that if turned the cam clockwise and let go, once again the auto adv. wouldn't fully return until I opened the points with a screwdriver. Is it that the springs in the auto adv. have weakened and are no longer able to overcome the tension of the points spring? The bike has covered 15,000 kms.
