- Fri Apr 18, 2014 5:43 pm
#3520
Hi again. I took Mark's advice and put SAE 90 in the Connie gearbox and most of it has found its way back out again - no wonder there was no lube in the 'box! It looks to be coming either from the vertical split between gearbox halves or between the main 'box and the end-cover. I assume it's a case of stripping from the timing side, splitting the shell and rebuilding with new gaskets & seals... Any thoughts beyond this? Stephen
Regards
Stephen
250 pre-unit Clipper
350 Indian Bullet Superstar
535 Bulsader
700 Conny
New 650 Interceptor
Stephen
535 Bulsader
700 Conny
New 650 Interceptor
