- Thu Apr 03, 2014 5:32 pm
#3455
Well I've gone round the houses on this one... Turns out my '59 'Bullet' was actually registered as a Clipper. Last night I decided to have a look at the forks as the lower tubes were a bit tarnished. I was going through the parts books and finally realised they are Clipper forks (also fitted to the Crusader). They don't seem to have any sort of hydraulic damping a la Bullets, but there is an oil level screw in the tubes and a drain stud in the bottom. I can't see any way to get them apart to clean inside - any ideas? There is no collar to unscrew on the tubes, the only clue seems to be a bronze bush (?) at the top of the main legs that seems to be brazed in? If so, what is the oil in the legs for?
