- Sat Mar 01, 2014 4:29 pm
#3314
Just carried out the following mods and I'm having real problems with excessive vibration.
PAV removed, Straight through header and turn out muffler fitted.
Air box and filter removed and sports filter fitted.
Carb re-jetted and slide upgraded.
Electric starter removed. (my timing was too advanced and it kicked back and shredded the sprag clutch)
Kick start only inner primary fitted.
18 tooth sprocket fitted.
Timing is now spot on 0.8mm before TDC. Starts first kick!!
Carbs are running a little too rich now.
The engine idles nicely. BUT....
In neutral with the bike on the centre stand the bike walks backwards if you open the throttle! the vibration at anything above low revs is unbearable, like a hammer drill.
Even through the sprung seat. After a five minute test ride, my arms ache and it's given me a headache. it's a lot more sluggish than I was expecting after the upgrades and doesn't seem to have much oomph.
Tearing my hair out and hoping someone out there knows what I've screwed up
Anybody got any ideas?
