- Mon Apr 16, 2012 12:00 pm
#11604
Terry, while I agree with what everyone else has said about cleaning and close inspection, you CAN re-use the crankpin if it is undamaged and measures up ok. I have done many thousand miles on a Redditch 500 which was rebuilt this way. The floating bush (which on yours has disappeared!) is designed to wear faster than the other components and is termed "sacrificial" in this context, ie, it wears out before the other parts. Remember, this includes the outer track which is in the conrod eye so check that too. This type of big end was designed in the 30s and is very reliable BUT must have a good flow of clean good quality oil. This does not necessarily mean you should fit high capacity oilpumps by the way, they can cause problems too! While you're at it, check the small end in the rod, I've seen cracks and ovality in Indian rods at this point. With a Redditch forging the small end can be bushed but I wouldn't risk it on an Indian one, I don't think the metallurgy is good enough. If in doubt, do the whole thing, it's your peace of mind!
