By devon john
#3118
i have a classic bullet with twin leading front brake.
i have bought a disc brake hub , disc etc .
will the later disc brake fork bottoms fit onto the my forks??
i see you can make or buy a bracket to mount the caliper on the older forks, but would prefer the right fittings.
#31995
Hi JOHN-------- You can fit the disc hub/wheel unit direct onto the existing legs with a couple of mods...1) Remove the cast-in deep "lug" on the L/H leg by sawing and filing....2)remove the bottom half of the L/H mudguard stay to allow the calliper to bolt on..............."Here's one I did earlier" as they say}----------------------------- Image-------------------------------------------------------------------------------------------------------------------------------------------------------- Image
