By Scalyback
#3067
Here is a still from the forthcoming film, "The water Margin"
Filmed in and around Tonbridge, Kent.
Scalyback productions.
By Paul M H
#32141
I went to get me work bullet out the shed day before yesterday and found it flooded up to the wheel hubs due to my shed being at bottom of garden in a dip and the drains got blocked by leaves. Lucky the water level had only just came half way up the crank case and no long term damage was done. After a good wash down and change of oils and a good once over with a oilley rag and plenty of elbow grease it seems OK took the brakes time to dry out so I had to remove the wheels and clean then properly with brake cleaner and re grease the pivots and links now work better than before but they need a good clean anyway.
