- Sun Sep 29, 2013 10:52 am
#2728
OK fellas, I have a real blind spot when it comes to the electricals.. so I need a little guidance here.
I fitted the case stiffener yesterday, easy job, no problem. Then I thought I'd fire Thumper up and try my handiwork out. Thumper won't start.
Now, I'm sure the two things aren't related, as one touches nothing electrical when fitting a little jig to the crank housing, so I have a problem somewhere...
I have no spark from the plug. I took the seat off and checked the connections at the coil and plug. All appears to be in order. The HT lead shows no signs of a break or being worn through. The plug is virtually new.
Can it be, that the coil just "died"? Or should I start tearing the nacelle to bits and go there?
I'm in a bind here lads, so any advice is well received.
I didn't buy the bike to add years to my remaining life. I bought it to add life to my remaining years.
Exile.
Find me (and Thumper) here: http://thumperdiaries.exilesplace.dk/#home
Exile.
