- Wed Sep 04, 2013 1:36 am
#2626
Okay, got the idle problem solved on my new, (used Bullet), now my concern is when riding with the headlight on my amp meter stays in the negative, with headlight off needle moves to the plus, is this normal? Shouldn't the needle at least read in the plus with the headlight on at higher RPM's? My bike also has electronic points unit and I have not found a proper adjustment procedure or specification for setting, it seems a little sluggish and wondering if timing needs advanced possibly?
