- Sat Aug 10, 2013 1:46 pm
#2539
Hello, I recently have purchased a 2004 RE 65 trials bike 500cc, 5 speed gearbox.
It is having problems with gear changes. When I go up through the gears( left foot gear change). When I change from 2nd to 3rd. It either selects a false nautral or engages and then pops out of gear. The popping out of gear is very annoying and is more common than selecting false neutrals. I use it in heavy traffic, so this is worrying, especially if you are filtering. I should point out. If you select a false neutral when attempting to change from 2nd to 3rd. And you try to reselect 3rd it will usually just skip 3rd and go to 4th or 5th instead.
Now I have owned an Enfield before with the 4 speed box. I'm aware about the different techniques different people will use to change gear. I have tried quite a few. But the problem still persists.
I have Pete Snidal manual. In that manual it suggests for firing out of gear. That it could be a Camplate issue or parts around the Camplate. Part numbers 18,20,21. Part 18 is the Camplate itself, part 20 is worn pawl end, 21 is soft or broken pawl spring. Or that it could be incomplete engagement. There is a whole other list for incomplete engagement.
What do you guys think? I thought I'd check first because according to Pete. To do the Camplate you need to remove the engine from frame.
