- Sun Aug 04, 2013 9:29 am
#2508
2003 Bullet 500
Long story but I'm trying to fit a new set of piston rings to an old standard 500cc piston. Even thought the piston is clean one of the new piston rings, the thicker oil control one, is too tight in there. The old one is a bit grotty but cleaned it and put it back and it's tight as well. Is there any trick to making this work or is it just a problem with fractions out?
I should say that I normally have a higher compression piston in there and had the bike stripped last weekend checking it over but broke a ring re-assembling. Ordered up the wrong piston rings so just to get on the road was going to put the fresh std rings on the old standard piston. Don't think that looks like happening at the moment.
I have cleaned up the old ring and popped it on but it's tight in spots as well. It just seems like the groove, in the piston, is just a bit tight for the ring in some places. Might have to leave it and wait to get proper rings for my higher compression piston.
I cut a piece of the old piston ring so I could run it around the groove to clean that out but even that short piece gets stuck in spots and it's not like there's dirt in that spot. The groove is clean metal and still I can't push the ring past the spot.
I'm sure it's a none starter and I'll have to wait for proper rings for other piston but thought I'd ask on here. There are many wiser heads then me here. Your words of wisdom would be gratefully received.
