- Mon Jul 15, 2013 1:12 pm
#2429
Anyone know how tho remove the outer race, washer and bush assy from the timing side.Warming it up isn't a problem, however, getting at it to tap it out is. Looks like the only place is on the edge of the washer behind the bush. Which side should the bush exit? Do I drive it in towards the bearing, or towards the timing pinion? Lastly, is there a conversion for this bearing so the rollers don't run directly on the crank surface?
