- Sun Jul 07, 2013 12:54 pm
#26343
Sometimes, a half-hearted kick can result in the engine firing and kicking-back - ie running backwards for part of a revolution. The exhaust gas therefore escapes back through the inlet valve and the increased pressure in the inlet tract blows the carb off its rubber mounting...........If the piston is not moving upwards quickly enough up to tdc on the compression stroke, this kick-back can happen........It can also happen if the ignition timing is too far advanced.....I would check the ignition timing, and also remember to put some effort into kickstarting.......Also ensure that the kickstart is at the top of its stroke with the piston just over tdc on the compression stroke so that the flywheels generate the maximum momentum to move the piston quickly enough for the firing stroke.
