- Sun Jun 09, 2013 7:29 pm
#2286
yes its me again. with your help I have gotten the motor running well, the gearbox shifting, but my new clutch won't disengage. I can see the clutch plates moving when U depress the lever on the bars, as I have taken the cover off. I put the plates in proper order - or at least I think I did. the first plate (dished) goes on so the raised portion of the dish faces the fitter, outward (away from the bike) the other plates go on and then the other dished plate goes on so that the raised portion of the dish faces toward the bike, inward (or away from the fitter) If this sounds correct, what do I need to look for next? I have started the bike on it's stand and can clunck it into first gear, at which time the rear wheel begins turning. When I depress the clutch lever on the bars, the plates move, but the rear wheel continues moving. I had put the stiffer springs on, and then tried returning to the original springs, doesn't matter - still won't disengage. How much movement should I expect to see out of the clutch plates, when I depress the clutch lever?
