- Mon May 27, 2013 2:00 pm
#25378
hi titch ,i have just done a full engine strip on an efi the big end was completely shot at 15000 miles now bear this in mind this bike has been serviced regular oil & filters changed religously at 2500 mile intervals but heres the crunch its been hauling a watsonian squire sidecar since around 2500 miles the engine started to rattle about 2 month ago and i told the owner to let it develope as once the rattle appears you can,t stop it it did develope just after going to the stafford show although the rattle was not a full blown knock but i decided strip down was the only alternative on stripping the big end was found to be shot ,i would think a solo should last for about 20000 miles although there is trouble ahead the efi uses the same conrod and big end as the electra (my electra big end went at 15000 miles and was knocking like a shithouse door on a grimsby trawler on stripping the engine the play was very slight but still up the creek)i also notice that the sprag clutch employed in the efi is the same as the troublesome electra ,and as i,ve already reported the electrical connections to all them sensors are terrible ,so as a great pal of mine once said" SUCK IT & SEE" they may be good and bad i must say that ive only seen bad ,although the combo is back on the road and clocking up more mileage ,the other thing is don,t worry our hosts can supply uprated bigends i,ve fitted 2 in the last 6 months happy days paul
