- Tue May 21, 2013 6:21 am
#2202
Has anybody got tips on the best spark plug ?
I have a highly tuned Bullet export 1995 535 cc , 9:1 comp ratio .
I seem to churn through NGK B9ES far too much and they soot up pretty fast , are hard to clean as I dont have my electric grit blaster plug cleaner any more ( nobody seems to have stocked them for many years } .
, Champion spark plugs seem to go up in smaller increments and far more swirl area with a longer center pin making them easy to clean , right now I'm on a Champion N5,is good for starting and it spits back less ...just past slow tick over . Due to the incredible warm sunny days since summer it's 20 degrees every day here in Sydney so I put off changing my Amal slide to a number 2 for our so called winter .
Does anybody else find NGK's have a short life ? The single cylinder engine with a missfire is hell so I carry spares but Champions seem to last longer overall . Does having a resister in the plug cap weaken the spark power . Does having a twin plug set up improve combustion ?
I changed my Lucas coil to a BMC Austin Mini coil which is oil cooled and though still made by Lucas it's just a little fatter in size , could this be part of my problem ?
