- Thu May 16, 2013 6:57 pm
#2187
Paul, Frank, Gwilly hitchcocks said the order of the springs makes no difference, first the strong springs followed by the others. I've been riding today and trying trying various settings in the gear box and at the lever. Still got the neutral going down into second, I think the clutch drags easily, the only thing left to try is an oil change as you all said before. Sorry if I'm going on about this but I have to have things right and my knowledge is limited. Sometimes I can't get the green ignition light on, especially when hot, but the engine will start if I hold the clutch lever when I press the ignition switch........does tell you anything???? Thanks for your help.....Dennis
