By morgy
#203
hi all first time on here,been out today pressed start buttern and it seemed like motor locked up,so took starter motor off+bike started second kick,so put starter back on + tried to kick over but felt like it was permenently  engauged, could not start again untill i took starter motor off,any help on this would be great thanks
#10714
Hi Morgy------stand-by for a chorus of replies-----altogether lads->>>>>>> SPRAG !!!!  Sorry to sound churlish but you have all the magic ingredients that says it's probally a 90% chance your sprag clutch is jammed.( Im assuming you tested the  starter motor for running when out of the engine ??) Others with actual hands-on experience will be along shortly to guide you through the actual mechanics of the whole affair. Are you / do you know --soneone with mechanical ability. You can save yourself a big wodge of wonga by doing the repairs yourself. What bike is it ?? Best regards-------
By Paul M H
#10717
Yes I would second that. It sounds like the sprauge clutch has jammed you may be lucky sometimes they just jam as one of the little ratchets bits turn over the wrong way but you will need to take it apart to find out anyway. If you can get by without the electric start you can remove it altogether and all associated parts saving a bit of bother and weight. They sell a blanking plug on this site for such purpose as its a regular thing people do I removed mine from my work Bullet so its kick start only. its not too hard to change but its around £90 for a new sprauge bearing.
#10718
 Morgy,
    The primary covers have  to come off because it sounds like the bearing has locked up and as the gear to drive the motor is in constant mesh, with the bearing locked up it can end up spinning the shaft in the housing so you need to remove the sprag and either replace the bearing or leave the sprag out completely. Millions of posts worldwide on what to do next.
#10719
 I think the sprag bearing is possibly ok, it will be the needle roller the gears run on but I haven't seen this bearing for sale anywhere but I'm sure our hosts would have them
By morgy
#10866
thanks to all for reply's will start the strip down then, yes i tested the started it's ok,+its a 500 classic 2001,and as for a mechanic my son is a mechanic for norton,this is the first enfield i have had +i love it,thanks again
By Paul M H
#10867
Update from my previous post where I said £90 quid its gone up to £115 pounds Plus VAT so I hope yours is OK thats around £140 including VAT and postage. Thats why I removed mine after the second one broke. Details are in the on-line parts books on left above.
Position 10
SPRAG CLUTCH
Code: 560011
Price: £115.00
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
#10887
Hello again Morgy---------Here's a straight forward question for you to consider as you dismantle the primary etc. Do you really want/need the electric start facility ?? Why not consider using our hosts "Electric start to kick start" conversion kit ??(  Page 42 ) For the same money ---£115 + VaT etc you will have an original  looking Classic 500 PLUS the added wiring, solenoid etc to add say air horns, or flashing spots. And--- you get to keep the heavy duty battery as an added bonus.
By morgy
#10916
ALAN-R  thanks for that but i don't think air horns + flashing spot's will go with the looks of a cafe racer but hey-ho each to there own
#10929
Hello morgy ---- OK, but by the same token does an electric "leg" look right on a Cafe' Racer either ??
