- Thu May 02, 2013 5:20 am
#24488
I have a 535 with sports cams and a skimmed head and use the alloy barrel spacer (1mm , 2mm ,3mm ) to go up or down for comp/ratio changes but at the moment it's about 9:1 , I have the Boyer electronic ignition with our hosts timing set info sheet , set at static with all the slop of the gears taken up and the boyer on full retard in static . Our hosts info sheet shows how to get it more or less bang on with their TDC plug measure tool giving reference in mm before TDC .
I trust our hosts instructions very much as my fitting is just one bike and our hosts have done hundreds if not thousands , the leading edge of the magnets can be done by eye , a center punch can mark your zero and you can punch every 2 to 4 degrees .
I run on 98 octaine as well and seldom get kick back on starting and so far no pinking .
