By bighazz
#2105
HI THE NUETRAL LIGHT ON MY 2009 BULLET TRIALS 500cc IS'NT WORKING HOW DO I CHECK AND CHANGE THE BULB ANY ADVICE GUYS. CHEERS BIGHAZZ.
By grunda 12
#24453
hi bighazz,i,m assuming you have a casquet the nuetral light bulb is under the green coloured dot in the speedo get at it by removing headlamp also check wiring connection at the rear of the gearboxor on top if an efi i think also check conections in headlamp if fitting a bulb fails hope this helps atb paul.
By Alan (Lancashire)
#24455
BIGHAZZ follow the wire going to the neutral switch , remove and with the ign turned on touch the wire to earth.
light comes on = faulty switch
if bulb does not come on replace the wire and change the bulb
#24456
-------------or, go for the cheaper option ie}--- learn to live without it. 1,000's of 4-speed riders manage ok ... (only joking---- but it's a thought, nonetheless )
