- Wed Dec 12, 2012 9:14 am
#20450
I recently had a similar problem with my 500. Tried the rope method, kick-over method etc. but all to no avail. I ended up making a hardwood 'wedge' which sits on the frame giving me a horizontal surface, then a piece of angle iron across the bike sitting on that. From there I used a combination of long clamps etc. to ease the head up (and subsequently the barrel). You need to be able to bring it up very straight, so the clamps each side allow you to do this. Thumping it will release the gasket it it's stuck, but after that PeteF is right that the problem is the old washers which grip onto the studs. When you put it back it's worth buying the hardened washers from our hosts to avoid the problem next time. But it can be a pain getting the old ones out even after removing the head as they get completely crushed inside.
