- Sat Nov 24, 2012 9:52 pm
#1486
hi all electra x sage,s,this is the query,on the left hand engine case is a stump of a non tapped crankcase breather ,is it poss to open this up to the crancase?would some kind of valve need to be fitted other than just a duckbill pipe ?if this is poss ,would the breather from the oil tank still be needed ?if its not poss is it best to run the catch potfrom the oil tank with a duck bill exiting the catch can ,on stripping the engine had a fair bit of mayo but had mainly been used for small jaunts,i would get shut of the pipe to the non existant timing gear train any thoughts welcome atb paul ,i don,t want an oil slick on the rear tyre!!!
