- Sat Oct 27, 2012 12:07 pm
#1370
Had a tough week with the 2003 Indian Bullet 500 kickstart.
I'm needing some advice but it's a long story. Compression has never been great on my bike but over the last month it's gradually disappeared. In addition getting home last week I got caught in the rain and the bike hates the rain and cut out a few times on the way home. There was a lot of kicking. I had thought it was a problem with water getting into the petrol but that wet Friday disproved that theory. I was trying to find the source of the problem and kicking for ages but got her going and got home.
So first up I know that the compression is sh1t so pull the head to hone the valves and decompressor. I was grinding away at the inlet valve but in my head it didn't seem right. It was actually slipping inside the valve seat which seemed strange. Thankfully our hosts were able to look at a few photos and tell me that it was a 350 inlet valve in a 500 bike. I've never messed with the head but did send it away to have a bigger exhaust valve fitted. I've no idea how a 350 valve go in there, and assume it came from the factory like that. So I ordered up the proper valve and honed it in yesterday. Now I have compression!
But now it really won't start? I've a spark from the plug but that's always a questionable diagnosis as it might well spark outside the cylinder but inside might be a different story. I'd a fresh coil sitting in my box of tricks and tried that but it makes no difference. It's got Electronic ignition I fitted years ago?
If it's not the ignition it has to be the carb? I've always said that the carb is the most complicated mechanical device ever created. Maybe I exaggerate but it's still a lot more complicated then I can get my head around.
Either way carb or ignition it's the kind of problem where you have to replace a lot of moneys worth of kit and that might gain you nothing.
Time for a cup of tea and ponder the next step. Any advice most welcome.
