By Modern_Day_Rocker - Wed Jul 27, 2022 12:11 am
#102198
Hello all!
My 2004 Iron Barrel specifications.
Accralite 535cc +20 piston. Fresh rings bed in. 160psi compression test.
Alloy Barrel.
Hitchcocks competition valve kit.
PricePart "R" Cams
Ported and polished head and seats opened up for oversize inlet valve.
Samrat Rockers and Hitchcocks push rods.
Pazon Electronic Ignition.
Mikuni TM32 flat slide jetted spot on.
Special fabricated airbox with built in tuned length velocity stack and 4in K&N Filter.
Hitchcocks oversize oil pump discs and spindle kit.
Port matched stepped header and straight through baffle short bottle silencer with fibreglass wool packing.
5 plate Clutch Upgrade kit.
19 tooth front sprocket.
PricePart R cams the cranking compression tested 160psi.
Stock Indian cams tested at 170psi.
Goal for this build is to have a nice mildly cammed tourer with a power delivery aimed between 2000 to 5000rpm/ mid range to top end for nice highway cruising. There's lots of open straight flat 100kmh/62mph speed roads in my area. But it still has to behave in town too.
My question is what are the power characteristics of the 200180 performance cams?
I tried the 90023 Hi Performance cams but couldn't get them to behave well enough for street use. Upon installing the 90023 cams it lost a lot of cranking compression from 165psi down to 120psi. To set the bike to idle, the rpms would "hang" when cracking the throttle or de-acceleration it would pull into corners, to set it not to "hang" it wouldn't idle, which would be done by screwing out the idle screw, so you'd be constantly be blipping the throttle. Jetting of the Pilot circuit had very little affect.
To improve the slow speed/ idle vacuum. I removed the base gasket and installed a 3-way pinion gear to the advanced setting which helped. Bumped the cranking compression to 145psi.
Didn't make the idle problem go away, just made it smaller.
Also these cams would have a lot of reversion if ridden around calmly in town around 3000rpm, it would fill the airbox up with fuel and exhaust vapor eventually turning the filter grey. These cams didn't start coming to life until 3500rpm. But they were a lot of Fun!
So at present the bike is jetted perfectly to the PricePart "R" cams with the Mikuni TM32 and use of a AFR gauge at a healthy 12.2 to 12.5 AFR at all throttle positions and loads. Nice chocolate brown plugs.
My biggest gripe is the "R" cams aren't exactly what I want. The power is a meaty bottom end like stock Bullet cams with a stronger midrange starts tapering off by 3500. Which at 3600-3800 is the cruising rpms for the speeds on my highways.
These "R" cams have very short duration and a aggressive ramp speed. So they clack away furiously at all engine speeds and sound very hard on the valve gear. The valve train noise is louder than the exhaust, which is straight through. Other cams (Stock and 90023) is the typical Bullet level of valve train noise.
I'm hoping the tamer 200180 Performance Cams are my answer for cams suited for touring.
Just the numbers concern me with my limited, but still learning knowledge on Cams.
Looks like a very narrow lobe separation angle and lots of overlap.
I don't want to run into the reversion problem and have poor next to no idle again.
The bike does have to be street friendly for town riding.
Any information or advice before I spend more money on Cams?
Thanks for your input!
Ben
Alloy Barrel.
PricePart "R" Cams
Ben
