- Wed Apr 27, 2022 4:22 pm
#100802
I am trying two different carburetors, different needles, different jets and still can’t get past 75 MPH.
I have an electronic gizmo for checking ignition for magnetos, it’s about 2-16mm which is well within factory range.
The valve clearance supposedly should be nil, since setting and defining nil is pretty difficult I’ve set clearance with the smallest blade on feeler gauge.
Not far from my home I have about 1,5 mile of dual carriageway which was bypassed by new expressway hence there is almost no traffic there. I do run both ways and check speed with GPS recorder.
Today I was trying 320 jet for Amal Monobloc 5/32. For the first time I have also tried to check top speed on third. To my surprise it was 80 MPH. So now I am really baffled. Top speed on third is higher than on fourth. It’s like top gearing is wrong. Like the engine cannot get into revs where the power is.
I have also installed electronic rev counter, it’s cheap and wildly inaccurate but with top speed on third it indicated about 6000 RPM which I suppose is in the ballpark.
Also with 35 MPH on fourth it shows about 2000RPM, again it’s more or less right. (17,5MPH for 1000RPM on fourth).
One of previous owners installed 21T sprocket. I understand there should be 20T sprocket, could one teeth make such a difference?
It’s not like I have need for speed but it would be nice to know it’s there.
