- Sat Oct 06, 2012 6:11 pm
#1271
Hi chaps, I need some help on setting the carb on my WD/CO. I have the correct carb 276AC/1A set up to the correct spec but for some reason it chokes the engine when it runs. There are plumes of black smoke from the exhaust so is running rich but I can't get it to run right untill I turn the petrol tap off. When the tap is off, within about 15 seconds the engine picks up and runs much better untill the fuel in the bowl has been used. I have no leeks apparant and at first I thought the float needle wasn't seating so I stripped it and rebedded the needle in with some metal polish. I checked the needle was seating by filling the bowl with petrol and it was perfect with no petrol escaping. So does anyone have an idea? I'm now thinking I better check the tickler isn't holding the float down or somthing like that.
Cheers, Chris.
Cheers, Chris.
