Hi Norm & Gwilly. It took me a couple of reads and this is what I think you have Norm? You are saying the blinker's warning (speedo)light is fed by both left and right blinkers and the warning light also has an earth. If so, all that is wrong is that the warning light should NOT be connected to earth. The warning light should be cross connected (In series) across both L & R live feeds to the blinkers which allows the warning light to work by "seeing" the earth via the very low resistance of the other sides bulbs. All four blinker lights complete their circuit through an earth connection. As the the warning light is very low wattage, it means it also has quite a high resistance, so the current through it is limited and is in the order of only about 1/4 of an amp. The blinker lamps are fairly powerful high wattage lamps and their cold resistance is very low (the resistance rises considerably when fully lit by the correct voltage) So, even though current of one side is cross connected through the warning light to the opposite side's blinker bulbs the current is to low it does not illuminate them and the resistance of the blinker bulbs (in parallel)is low enough to let the warning light illuminate nearly to full brilliance. This action works either way from L to R or R to L. So all you have to do Norm is check that the warning light is driven by both live sides of each sides blinkers...& remove any earth from the warning light bulb holder...it needs to be insulated from earth. SO gwilly is right with his description. Hope I've understood your problem, otherwise I've wasted my time
or should it be?
