- Sat Jan 08, 2022 1:06 am
#99616
outer bush.jpg (467.06 KiB) Viewed 9897 times
Apologies to all for my first post not being about Royal Enfields, but you guys seem to be the most knowledge when it comes to Albion gearboxes…
I´m a complete noobie, so apologies in advance. Mine is a ROA Super Foxter 200 (1960) that’s not run for about 40 years. Its a Spanish bike fitted with a Villers 197 7E and an Albion 4-speed. As far as I know, there´s nothing wrong with the box, apart from 28,000 Km of wear and tear and 40 years of rusting in a barn…
Unfortunately, when it comes to the gearbox, I´ve fallen at the first hurdle. From what I´ve read in Motor Cycle & Cycle Trader´s Servicing Data Sheet No. 4 and referring to the exploded diagram (Parts System | EXG074 (villiers.info) the “Bush operating shaft outer” (9) should just slide off the operator shaft (20). But its stuck solid. No amount of pulling, heating or WD-40 has shifted it a mm.
Any suggestions appreciated!
