- Fri Feb 19, 2021 1:49 pm
#95294
Following fitting a new Mikcarb and having overhauled the ignition system ( to fix bad staring from cold problem) the 350 bullet was flying it. Going like a bullet in fact. Seduced by this performance and frustrated by the lock down I admit to giving the old girl a lot of ungentlemanly full throttle, just to see how how far the needle would swing to the right. Bullet and rider were happy until we got home and I noticed a lot more tapping coming from the cam followers. Inspection in the morning was the same, and the bullet refused to start. Compression was down and it barely fired once. Tappet settings perfect, no bent push rods or such like obvious stuff, so I took the head off. Without the pressure of valve springs the tappets were silent, of course. Exhaust valve pretty badly coked but intact. Inlet not so hot either so time for all that business . I took the barrel off while at it to check piston and bore. Both perfect.
Question one: Any ideas for the cam noise--a distinct "clack, clack" as the cam meets the follower and rides over the hump.
Question two: How much side play on the con rod/big end floating bush is right. I can detect nil up and down movement on the big end by grabbing the rod and tugging up and down. The small end of the con rod "appears" to rock from side to side in conjunction with the visible side play at the crank end. But no up and down movement.
The bottom end was rebuilt 5000 miles ago .
It is a 1990 350 bullet, Indian home market model.
I have checked the oil flow everywhere, and is good.
I can deal with the head overhaul etc but not with the head paranoia!!!
