#1111
Anybody know what is the correct spark plug for these, I have gone through the online manual I have and with 57 pages of info not a mention about the spark plugs
By Martin
#17052
Norm, in my '49/'52 500 twin
ignition timing query you had
kindly answered a day or two
ago, I had wondered the same.
Our host's manual gives KLG 50
Champion L10 which is NGK BH5
for both the the early 500 and
700 twin. Yorkie must had access
to a Champion manual which said
the same thing. Someone perhaps
may update this somewhat with
contemporary unleaded gasolines
or multi-grade oils used now
though. Gordon
#17053
Thanks Gordon, no idea what a KLG 50 is but we have 2 of them here and they were/are fitted with KLG B7HS I wanted to be sure before I replace these NGK's which are 2 weeks old and one is misfiring and making starting a problem. I will not be replacing them with NGK
By Martin
#17054
Sorry, Norm, sloppy typing.
meant KLG F50 which were as
common as NGK once way back.
Champion L10 still around are
as common as house flies.
The NGK equivalent is B5HS.
Would think NGK B7HS was near
enough meanwhile, but remember
duds when I used dozens with
several Suzuki GT750 years ago.
Gordon
#17056
Gordon,
I went through 6 or 7 NGK plugs in my Bullet last year on our trip around Tasmania which took 5 days. and probably wasn't much more than a 1000ks
By Shirty
#17061
Hi Norm,
I have just put some Champion L10's in mine, seem to be ok (other than the left one oiling up due to the problems previuously mentioned!!)
Cheers
By Yorkie
#17064
Norm,the correct plugs for the 500 twin and 700 Meteor are
Champion L10 or KLG F50,gapped at 18/20 thou" NGK B6HS = L10
NGK B5HS = F50
If you are fitting NGK B7HS,these are too cold and will not self-clean,hence
your plug fouling and misfire.Pilot error!!
Yorkie (from Briggs & Stratton)!!!!!!!!
#17066
Thanks for that I'll see if I can pick up a couple of L10 this morning and see how they go.
#17091
I couldn't get the Champion plugs so I went with another option Bosch W7AC and life is now good again in Meteor land
By dookie
#28602
Just out of interest, my 1953 Meteor had been sitting since 1966 and upon restoration I found it had KLG F70 plugs in it. I was wondering if there was a particular reason for this?
