By Mortimer_L
#1091
Dear all,
I have recently acquired a 1946 RE 125 'Flying Flea'. I have not had much to do with engines and gearbox's in the past and wish to have them sent to a professional to have re conditioned.
I have looked around a bit and have come up with nothing.
Please can someone recommend somebody who will be able to help??
#16953
Mort, are you sure it actually needs rebuilding? I'd try and run it first, it could save a lot of bother if you know roughly what's wrong. We have recently had a Poster here who has been going through the same issues, search the Message string for his example. If you do need someone, I can offer a few names.
By Mortimer_L
#16954
Mark,
Thanks for your reply, I have had a look through the forum and found a few areas which are of much help.
The reason to looking into sending it away is due to the amount of use it will have in the first 6 months or running, and knowing that I need it to be reliable enough. Regards Lawrence
By Mortimer_L
#16955
Mark,
#16964
Mort, I'd still get it running, a running bike even if faulty will help to identify associated problems, eg with electrics, carburation etc. What is this possible heavy use you darkly hint at?!
