- Fri Jun 26, 2020 12:43 pm
#91061
Hi all. Do you know you can only start a new topic after you've added to a pre-existing one?
My 1951 G2 came with its speedo cable draped over the saddle. Didn't work well like that either.
So where should I run it?
Down the left side and under the engine then over the swinging arm pivot?
Any suggestions welcome
Actually I have another issue and that is that the worm drive keeps slipping out of the drive box (rear wheel) see image. I can keep it in place if i ziptie the cable tightly onto the frame, thus forcing the wor drive back into place. But that can't be right. Is there some spring washer I should place on the drive worm? BTW, the threaded screw in the casing centre in the image is not a lock screw.
Cheers, ChrisD
Cheers, ChrisD
