- Sun Jun 07, 2020 1:11 pm
#90563
Here's what I did, only necessary once.
Bike on stand, plank of wood on seat, car jack on plank, strop/rope from either side of s/arm over jack, raise jack to compress suspension, jack until hub centre, s/arm pivot and gearbox sprocket in straight line with one another. Then adjust chain to no slack position. Release all the above jack etc.
Chain adjustment is now perfect; if you then measure free play on chain with bike just on stand then this is what you will always set it to in the future. Even if new chain etc fitted this measurement will still remain correct unless you change suspension ride height - write the measurement clearly on the garage wall. (I moved house,so must do it again!!)
