- Thu Apr 16, 2020 11:41 am
#89336
There is a question for my knowledge later, but the first big is just an observation.
2002/3 350 Bullet
As a newbie to the RE world, I’ve just adjusted my drive chain. Now that I’ve done it once, it is very straightforward, but had I not read the workshop manual, I would not have undone the ‘rear brake anchor pin nut’
Interesting the way the right hand side of the axle seems to swing away from the snail adjuster, had to hold the wheel to the left to line up whilst tightening. I assume something is under tension in there.
And what a difference in chain slack one notch on the adjuster makes! Went from way too loose to the short side of correct tension. Don’t worry, I have the right amount of slack, I’m fully aware of tight chain issues.
I’ve used snail adjusters before, 70s 80s traillies.
Okay, a question out of interest. What is the stub axle nut for, behind the castle nut?
Never had a bike with two nuts, not the riders! Is this something to do with the fact the rear wheel is detachable without sprocket?
Thanks
John
2002/3 350 Bullet
Thanks
John
