Hope this will be the right one!
Hi all, sorry I'm "spamming" the forum, but I hope this thread will be useful to someone else facing my same problems.
Yesterday I made some new test and I can say the problem is DEFINITELY on the carb.
Let me recap:
Now I have 3 carburettors Carb1 - the original one MIKARB Carb2 - a spare used carb MIKARB Carb3 - a brend new carb from India branded "Royal Enfield" (no idea if it is a fake or original one).
This are settings:
Carb1: needle: Y373 (now replaced with Hitchcock one labeled A(or DELTA) 4H7
needle clip: 3
throttle valve: 2.5
air screw: 2 turns
float: 24.5mm
Carb2:
needle: A(or DELTA) 40H7
needle clip: 3
throttle valve: 2.0
air screw: 2 turns
float: 24.5mm
Carb3:
needle clip: 3
throttle valve: 2.5
air screw: 2 turns
float: 24.5mm
This are the behaviours of the engine
Carb1:
starts with choke idles without choke
coughs and turn off when using the throttle without choke
it runs with choke on
Carb2:
all works fine!!
Carb3:
starts with choke
doesn't idle without choke
fires from exhaust when using the throttle
Ok, the main difference seems to be the throttle valve! So I tried to use the Carb2's valve on the other carbs.
Carb1:
all works fine!!
Carb3:
starts with choke
I can't find any logical explaination of all this!
Ah, if you ear about any "carb assemble/disassemble" championship, please lete me now! Now I can dissasemble, separate part by part, clean and reassemble Bullet's carb, in less than a minute, without tools, with an and tied and with a blindfold on!
