By enfield_trials
#75617
Thanks for all your interest and actually i still havent pick up frame/engine from my friend. will share the picture once i bring her home.
@Bullet Whisperer
90 mph is bit of speed, i believe you can take it even further. I would love to see Asbo on Salt flats , i think it will break some records,.
By Bullet Whisperer
#75618
Funny you should say that, enfield_trials, but a few years ago, on Pendine Sands, we recorded 95.76mph from our 350, which was sufferring with pre-ignition problems, due, it turned out later, to the CDI box being too close to the ignition coil and the 500 managed 110.51mph. Both machines have gained a little power and speed since the. The 350 uses a Crusader frame, by the way ! Regards, Paul.
By martyn15
#75782
well done chap. I think you will need a Crusader sports swingarm like this. its wider at the front to accommodate a 4.00 x 18 trials tyre and the flat axle plates allow a larger rear sprocket to be fitted. Have a look at John M's pics. Ive just started on my own Bullet/Crusader trials proj.
how do i delete my tumblr account
By John M
#75789
An Indian Bullet swinging arm will fit the Crusader frame, ************* BUT ************ the lower shockabsorber mounts are further back and 6mm wider than the Crusader so you would have to modify this mount.
By enfield_trials
#75961
@martyn15. JohnM
Thanks for your feedback and encouragement. sometime if look for some part , it becomes like hen teeth.
i will see if i can find wider swingarm. or use bullet one as suggested. some people use below procedure on c15/tiger cub wider the swing arm. not sure it possible here
@Martyn15 keep us posted regarding your bike progress
Regards
ET
By John M
#75962
Can't help thinking that it would be a lot easier to modify the shock mountings on an Indian swinging arm and a standard Indian hub would fit it.
By enfield_trials
#75963
@John M . i am not skillful as you guys. local welding guy will be doing the job. thought other might be easier path for him. ...
i agree to your point. make sense.i will be using standard bullet hub as well
