For Alan R (and anyone else who was wondering...).
The inner chaincase on the pre-EFI electric start models is mounted at different points where it bolts onto the l/h crankcase, in order to clear the starter motor's gear train.
If you eliminate the E/S mechanism completely and fit the kick-start inner chaincase, the three mounting stud holes no longer line up. Fortunately the E/S models crankcase castings still have the metal in place to allow the stud holes to be drilled and tapped in the original position. Have a look at the gasket section of our hosts' catalogue at part nos. 144621 and 560052.
http://www.hitchcocksmotorcycles.com/ac ... ls-classic
You will see that the gasket to fit between the inner chaincase and the crankcase will have the three mounting stud holes in different positions for E/S and K/S models. You cannot just rotate them round because of the position of the hole for the 4th stud, upon which the primary chain tensioner pivots.
I did this mod with my Electra's conversion to K/S only and will have to do it again for the current project.br>
