- Fri Mar 04, 2016 8:49 am
#55907
Thanks for your replies.
Mark...Re: replacement mag sprocket....Haven't got one yet but, but it looks like Mr H has new ones available, I will also need a new duplex chain as I had to split the old one, so will get that too.
Dennis....yes a real shame ...never had dealings with him before but talking on the phone to him he's a very friendly helpful bloke....I asked him what he was going to do with his business but he said he couldn't find anyone to take it up...you interested?
I have fixed the original broken shaft back onto the front brass end section by tapping the shaft with a M^ and bolting it from behind with an M^ bolt....also used strong (LMP 3% Ag) solder to reinforce the break...seems as strong as original so will rebuild mag with new capacitors as winding OK...obviously will replace bearings, seals, etc. too
Thanks Mike for recommending Tony Cooper, I had heard that Tony has an excellent reputation and also he supplies most of the others with sundry parts...
My last mag was re-wound by Dave Lindsley...supposedly he is rated, but he made a right mess on the outside of the armature metal work, leaving heavy gouging where he had gripped it with high pressure in a rogh jawed vice then filed it roughly up to clean it. When I sent it was immaculate with bright shiny brass ends and bright steel armature core...I was gutted and he just made excuse after excuse when I complained bitterly to him, he's also a very impatient brusk bloke to communicate with too....AVOID him if you care about your Mag...By comparison the mag I've stripped is unmarked and I don't have the luxury of all the right tools to separate the thing!..Les
