- Thu Feb 26, 2015 11:57 pm
#44747
Eureka, problem solved !!. Well, turned out to be the rear light earth after all. What threw me though, was first time I rigged up a temporary earhwire to the bulb holder it was the brake light filament that lit up. Well, Scalyback was right, out of interest I ignored the pin positions on the bulb and put it in "wrong way round". Hey presto, the tail light came on. Still no brake light, so took out the front lever switch, pressed it a few times, then on came the stoplight. Put the switch back, tried the footbrake and the stoplight worked again. Now all I have to remember if I need to change the bulb, to ignore the pin positions cos the holder is wired the wrong way around !. Anyway, thanks for all the help everyone, really appreciate it Now just need to sort out the running problem, but I`m on more familiar territory there and pretty sure it just needs the needle moving up a notch or two, or maybe a larger main jet.
