- Mon Mar 25, 2019 8:19 pm
#81957
There is also a slight chance of the valve seat coming loose.
If the seat comes loose the pushrods get out of control, too.
Just for piece of mind, you could check the distance of the valve stem end to the bottom of the head/lower spring washer and compare to what it was when you fitted the valves...and hopefully noted the readings.
