- Mon Jan 18, 2016 3:08 pm
#54339
There’s something very wrong if an iridium plug comes out heavily caked with carbon. NGK suggest a working life of up to 120,000 miles, the fact that these plugs in some of our bikes are failing after less than 100 miles points to something major that’s going wrong!
They also recommend that no attempt is made to adjust the gap on Iridium plugs. There is a risk that the very brittle central iridium electrode may fracture and, in use, fall into the cylinder. The plug gap is pre-set by the factory and, due to the efficiency of the Iridium plug, the factory-set gap will be suitable for virtually all applications. The same risk of the tip breaking also applies to cleaning iridium plugs.
