- Sat Dec 27, 2014 11:24 am
#42681
i thought the solution was clear with what was explained.
take the primary chain of, put the hardend spacer on the shaft.(be sure there ar no protrusions from the original steel on the back of the clutch center)
put the clutch center back, put the steel ruller on the clutch center sprocket.
measure the distance at the crank sprocket.
then you will have the distance that will have to be machined.
dont forget to subtract the thickness of the hardend spacer from you measurement.
