- Sun Jul 13, 2014 7:03 am
#37344
Frank another thing is the Electra doesn't have a seal on the timing side shaft, they figured that if the timing chest oil drained into the sump, so what the pump would clear it quickly and the 3 piece oil ring is the same as used in a wet sump motor so oil up around the underside of the piston would not be a problem
