- Sat Jun 28, 2014 8:56 am
#36848
Hi Simon
My old 77 350 had much the same set up as yours albeit with the uprated oil pumps and std barrell.. I was running an AMAL Monobloc and it went very well... I also had the competition valve set up and the close ratio gearbox with a 17 toothed final drive sprocket fitted...
Have you changed your Gearbox sprocket? mine has a 17 (16 std on Indian bikes) and that's given it longer legs on the odd occasion it wanders onto a motorway! I havent done any other mods to it yet worthy of note.. Still deciding what way to go with it......That'll all happen in the winter.
I was wondering if there was any advantage fitting the Forged piston over the Higher Compression piston as both are 8:1 so other than the fact that the forged item may or may not be lighter than the higher compression piston i cant see the justification for forking out the additional £100 for the Forged item over the cost of the HC Piston..... Just wondering?
Tom
Tom
