By Alan (Lancashire)
#35776
follow the indicator(s) wires inside the cascette there will be 2 wires , one will go to earth the other to the loom wiring , they are usually wired to a connector/bullets etc , unplug those connectors and add the 2 wires from your warning light , remember LED are polorised , neg to neg poz to poz , this idea will work for 2 lamps , if you want only one lamp come back for more info
By Gaffer64
#35795
Hi Alan,
Many thanks for the reply. Please could you also advise on the wiring for the LED to light the speedo.
Cheers
Mike g
#35804
"Please could you also advise on the wiring for the LED to light the speedo" ,,, take a feed from your side light/pilot lights , be careful as your led is orientated (neg to neg , poz to poz)
